jwelectric
- North Carolina
What???...the Board members seemed uncomfortable with the prospect of being the first jurisdiction in the West to implement all of the changes incorporated in the 2008 NEC
I thought the idea was to SAVE homes with these products? I guess it's ok to let a few homes sizzle in a "soft market"...it might spur some additional economic growthThere was also speculation that the Governor would not accept any code change that could significantly impact the cost of construction in a soft housing market.
wireman71 said:Not sure Idaho even needs the NEC.. Last I heard you didn't even need to have journeyman to run a company in Idaho.. Half kidding but I've seen some sketchy companies with more apprentices than journyman over there.
I'm not so sure they would sizzle ,.. and the cost impact on the market is real.celtic said:I thought the idea was to SAVE homes with these products? I guess it's ok to let a few homes sizzle in a "soft market"...it might spur some additional economic growth
Volume I NFPA Standards council Meeting July 14 2004
My name is Jeff Inks with National Association
of Home Builders.....
To give you an idea, talking about
the cost impact before, for every, I'll toss it out, for every $1,000 you increase the cost of a house, you are knocking of 250,000 potential home buyers out of the market, that is home buyers, potential home buyers in that medium price income range. You take that to actual number of buyers currently looking for a new home at the time that cost
increase occurs, you're knocking out around 25 to 30,000
buyers from that new home by raising that by $1,000.
It has a very, very real impact. And a lot of
logic -- and it makes common sense to say if you can
afford 202, you can afford 203, if you can afford 203,
you can afford 204. That's simply not the case. We all know in our own experience with lenders in the banking system, they draw the line. That's what happens when
you add these costs, the line gets drawn, knocking more and more people out of the market.
paulyoung said:By the way this is my first post but I have been lurking and learning from you guys for quite a while.
Paul
raider1 said:Idaho doesn't have a master electricians license.
raider1 said:You are required to have a journeymans license to operate an electrical contractors business.
raider1 said:Idaho has a pretty comprehensive journeymans test.
Chris
M. D. said:Paul don't be afraid to lay it out here ,... I had a teacher ,we all did probably , that said "the only stupid question is the one not asked."
This is a great place for us to challenge our most deeply held beliefs and traditions, in short jump right in, there is no water in this cyber pool , there ain't no pool either , so no chance of drowning ..
paulyoung said:Chris,
I'm not sure what year they created the masters license. I've had mine since 2001 and I know it was around for at least a couple years before that.
After I passed the test and went to get my license the head of licensing told me at that time there were only just over 100 masters statewide, primarily because,as I stated earlier there is no incentive to having one. I expect all that will change if and when the contractors requirement changes.
Paul
Just curious why you have Idaho apprentices in your class?
