IEC std. for oil-immersed transformers
skeshesh
Los Angeles, Ca
Hello everybody - hope you're all doing well.
I started researching the topic of overloading oil-filled transformers while working on a project involving a transformer that may be slightly overloaded when all mechanical loads are running. Although the max possible overloading is around 3-4% and is likely that it may not even happen, I figured I should dig deeper while on the subject. IEEE C57.91 was a good read but I remember looking through an IEC standard for overloading transformers a while ago that seemed more geared towards application, but I can't find it now. Can anyone point out the standard I'm looking for? All other thoughts or recommended reads are of course welcome and much appreciated.
