MyCleveland
- Cleveland, Ohio
I need help in resolving Vs value....whether it is positive or negative for a given problem.
If someone understands this method and can spare the time, I would appreciate four example problems where 2 result in a positive Vs and 2 result in a negative Vs.
Not written out results... just the problem parameters that result matches Vs provided.
EX: 480V-3p load, 200', #4/0 CU wire (1 set), conduit type, 175 amp, PF = 0.9
Result Vs = xx.xx degs (positive or negative)
