I have attached a ignition circuit diagram for an ATV and wish to confirm the meaning of the diagram and the testing method.
The ignition switch has 6 connectors marked A,B,C,D,E,F. See attachment,right hand side.
I don't think I am interpreting the circuit correctly.
Key in "off" position there is continuity between E&F, and no continuity elsewhere
Key in "on" position there is continuity between C&D, and no continuity elsewhere
Key in "start" position there is continuity between A&B, and no continuity elsewhere, including C&D
I am not certain what that small two-sided arrow nor the red line between D&E signifies, can you clarify?
Thanks!
Thanks!
