ultramegabob
- Indiana
iwire said:Receptacle inside or outside the cabinet I see no real issue.
me either:wink:
iwire said:...on the other hand a cheesy office max two drawer file cabinet is going to move around.
iwire said:I don't know any code rule that prohibits ruining conduit to something that can be moved.
paul said:If we were only allowed to hardwire something that was considered "permanent" then there would be allot of equipment out there that couldn't be wired.
More to the point, perhaps, is that there is no law that requires using a little common sense. :wink:growler said:As far as know there is no law against useing a little common sense.
growler said:...then why not set a couple of old oil drums on the floor and secure conduit to them. There would have to be a line drawn in the sand some place.
charlie b said:More to the point, perhaps, is that there is no law that requires using a little common sense. :wink:
How do you run conduits across a rubber roof? :grin:growler said:I wasn't thinking that you couldn't hardwire certain items but if you allow conduit to be secured to a fileing cabinet then why not set a couple of old oil drums on the floor and secure conduit to them. There would have to be a line drawn in the sand some place.
They're normally just strapped to chunks of pressure treated 4x4 or one of the similar premanufactured rubber block things for that purpose. Just sitting on the roof
iaov said:Is a file cabinet listed a support?
Good question Jim. I wish I had a good answer.jim dungar said:Is a stud wall a listed support?
