fandi
- Los Angeles
- Electrical Engineer
Hello All,
I googled but could not find any manufacturers. Maybe I used the wrong terms?
The intent is to run EMT conduits above ground to pedestal based electric vehicle charging stations (EVCS) at a parking structure. The pedestal will stand on the concrete raceway. I already have the EVCS cutsheet showing pedestal dimensions and the EVCS weight. Currently in the field I see concrete hollow blocks (elec conduits run inside) have been used for existing EVCS but I can't find any contact information to call. Also the hollow rectangular 5"W x 4"H is not big enough to run (20) 3/4" conduits anyway.
Alternatively, if I can't find concrete manufacturer to make it (Jensen precast said it has to be custom built) I'm open to other raceway types since concrete wheel stops will be installed anyway.
Thanks a lot.
Thanks a lot.
