StephenSDH
- Allentown, PA
I found a distribution panel that had the neutral and ground lugged together in a 400A 480V panel on the opposite side of the plant of the service.
I am planning on seperating everything next weekend.
My questions are:
What are the effects of having some current flowing through a building under normal operation?
During a lightning strike, do you believe equipment failure would be more likely? I believe you would be more likely to damage equipment but I am not a 100% sure.
Any other things to be aware of?
The customer has experienced alot of equipment failures. They said it is from lightning.
My questions are:
