eir
New member
- United States
- Let's begin with the #6 bare copper wire from the 200 amp breaker box that runs 20 feet across the basement to an iron water-supply pipe.
- The location where the copper wire connects to the iron pipe is an additional 15 feet from where the water supply enters the home through the brick foundation basement wall.
Ok, even though it should be connected 5 feet from the water line's entrance to the home, here's my question:
Will the "quality" of the ground improve by my moving the bare wire closer (i.e. within 5 feet) of where the water supply pipe enters the home through the foundation. By "quality" I mean will I have a more efficient, more effective ground being supplied to the residence's electrical system, OR does moving the wire/pipe attachement closer to the entry point not typically make any difference in this regard?
Thank you very much for your opinions!! :?
