In ground pool
guschash
Ohio
Home owner is putting an all metal pool. Would I bond this the same way as a concrete pool with re-bar in it? Do I attach the bonding wire to four points around pool or is one point sufficient since its an all metal pool.
Hopefully there are places there for the bonding otherwise you will have an issue. Make sure before it is bought that it can be bonded,
The all metal pool kits I have seen or been involved with have so many bolted connections four points shouldn’t be any issue.
For that matter 4-40 points wouldn’t be an issue
There is usually an empty hole on some of the metal wall sections that you can put a bolt, lug, & nut on. If not, just remove one of the bolts, add a lug, and put the bolt/nut back. You do this in 4 sections, equally spaced around the pool.
