In ground splice box
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
Scenario
I went to a job the other day and the builder had a beautifully dug trench about 24-30 inches deep. The run was about 200 feet. The problem there are 7 90 degree bends in the run. I will need to run #4 copper to the separate structure from the house. I installed 1 1/4" pvc and stubbed up for a box halfway thru the bends.
The Question
I want to use an inground splice box. All I can find are these 200-250 dollar boxes that are metal. I have seen some boxes that are nema 6P that are all PVC. Can these boxes be installed in ground? If not what can I use?
I guess I am looking for recommendations.
I realize I could have used USE cable but I didn't want to for various reasons. I was going to use UF cable but no one stocked it and the trench was ready. So it is what it is. Any suggestions-- I have never had to do this. The kicker is they could have done the trench with 3 90's if they did what I asked them to do.
electricalperson said:
how about using a green flower pot or hand hole box?
I am not sure what is legal. Can I install a standard PVC weathproof box and set it in the ground if I build a hand hole around it? or does it need be a specific box fo that purpose?
ive done that method before and never had a problem with inspectors. heres a link to the boxes i w as talking about http://www.americantechsupply.com/highplastic.htm
just use weatherproof wirenuts and you wont have a problem. the power company around here requires us to use the green plastic hdpe boxes for underground services.
maybe you can get a concrete enclosure with a solid bottom
another problem might be actually supporting the pvc box inside the handhole. i used galvanized angle iron screwed to the side and never had a code issue with inspectors on that.
Why do you want a box? just do a hand hole and be done with it... http://www.newbasis.com/
And one of these.. IDEAL
Dennis Alwon said:
Scenario
The Question
You have stub up's . Are they coming all the way out of the ground? If so you don't need an in ground box. Just one suited for wet locations. Mount a plastic box on a 4x4 or two.
An in ground box would be rare because a box is suppose to be accessible.
You should have used #2 AL. direct burial. But you know that already.
Okay, I write slow. You can get one of those green boxes from the posted link at the big box store. I thought they we're for water meters
i dont like direct burying triplex. incase theres ever a problem you need to dig it all up and start over. i always sleeve my triplex in DB.
I deliberately didn't use aluminum-- I hate aluminum and the HO didn't want it either.
We also don't want the box above grade- yuck.
stickboy said:
Why do you want a box, just do a hand hole and be done with it...
I actually hadn't thought about that-- I guess it would be legal with thhn since it is not buried in the ground.
Any idea of cost? And how would you size these boxes?
I would rather have AL not spliced in the ground.
Rather then copper spliced in a "ground box" that will most likely fill up with water.
See 314.30. Answers all your questions. Pay close attention to (C) as the wet location terminations for a #4 are not cheap.
Yeah, thats why you provide drainage and the splice has to be rated for WET location anyhow.
sort of off topic but i recently had to troubleshoot some low voltage landscaping lighting that didnt work. the original person who installed it (probably a landscaper) put the flower pot too low and put sod over it. luckily i had a good circuit tracer that was able to locate where the splices were.
mdshunk said:
Use a Quazite box. For a couple 1-1/4" pipes, a box suitably sized would only be about 40 bucks.
I am in total agreement with Marc...for the $......I have used them and recommended them on a strange site lighting job today as a matter of fact.
i have never seen a quazite box under 100 bucks, a 12x12x12 is $112 my cost... they are too expensive for residential IMO.
I guess it might come down to popularity. I can get little one's for as little as 20 bucks. The 12x12x12 you spec'd is the one I said I get for about 40 bucks. I do see a lot of guys leaving the supply house with the green plastic one's lately, though. Some of them are only about 9 bucks.
yep, I can get a 10x10 round for $14.50 from newbasis...
