Aleman...yes it is variable tension o volts web spool spins freely 24V it is locked (synchronized with 1st spool). There are 2 spools that a a plastic film (stretch wrap((web)) is stretched between.
A motor directly drives spool 1 and the 2nd spool is connected with gears and the clutch I am talking about. so the 2nd spool sees the stretch wrap from the expendable roll and pulls it off the roll while the 1st spool pulls it off the 2nd roll and stretches it. How much it is stretched is dependant on the voltage (current) to the clutch.
one thing is for sure you cant have current without voltage and voltage without current. Meaning I don't know if its the voltage or current that is actually varied all i know is that at 24V it pulls .5A and 0V=0A If you had a power supply that could supply 2000000000000A at 24V I would think it would still draw .5A at 24V so to me its voltage controlled and current follows by ohms law. Of course you could look at it the other way and pose the same argument either way its all related through power. If I supply .5A @ 1V i don't know what it would do but my guess is it wouldn't be locked or fully engauged?
Power to me is most meaningful as long as you have one of the other components... maybe there is someone who has a simple example as to the difference of the way it can be controlled?
