rgoodwinelectric
I've installed a transformer and when I've tried to power it on it trips the primary breaker and also the fuses at the SES. Not sure if this had something to do with the in-rush current so I requested a cut sheet from Federal Pacific (attached). When I powered the transformer on I had no load applied and the main and all branch circuit breakers were off in the secondary panel. I'm certain the install and wiring are correct, but am unsure of the math of the in-rush current here and if the main fuses can handle it. I've attached a spec sheet for the fuses also (JDT 200 Amp). Any help is greatly appreciated on this one.
Thanks!
Thanks!
