Don-R
New member
- San Diego, CA USA
Attached photo shows Carlon old work receptacle box mounted in outside stucco wall that will see beating rain.
The dimensions of this box are smaller than the usual properly designed weatherproof boxes.
All In-Use cover plates that I have found are designed to seal to properly designed weather proof boxes. Thus they will completely surround but NOT seal to the Carlon box.
It is questionable whether the gasket supplied with the In-Use cover will effectively seal to the stucco.
Thus it looks like the only way to make things weatherproof and raintight is to apply a heavy bead of caulking material around the In-Use cover plate where it meets the stucco surface.
Will this approach satisfy the wet location requirements of the code?
