winnie
- Springfield, MA, USA
- Electric motor research
GeorgeB said:120/130 squared is about 0.85, or 15% less power. [...]
Is there more to this? Perceived brightness from lower color temperature?
George
Yes and yes.
The _vast_ majority of the output of an incandescent lamp is in the form of invisible infrared radiation.
The proportion of the output that is in the IR depends upon the temperature of the filament. The cooler the filament, the less total radiation it puts out, _and_ the greater the percentage that ends up as invisible IR.
When the lamp is operated at 120/130 of its nominal full voltage, then the filament resistance goes down about 4%, and the power consumption goes down about 12%.
This means that the _total_ output will go down about 12%.
But the output is also shifting more toward the IR, so the _visible_ output goes down about 24%.
The term 'color temperature' is a way of describing the spectral distribution of a light source. A 'perfect black body radiator' at a particular temperature will emit light of a particular spectral distribution. Color temperature is the thermodynamic temperature of a black body who's spectrum best approximates the real source being described. A 'black body radiator' is an idealized hot surface, giving off light with no reflection or color of its own. A tungsten filament is actually a pretty good approximation of a black body, so the color temperature of an incandescent lamp is pretty well the temperature of the filament itself.
Please note that these are only approximate numbers.
-Jon
