kwired
Electron manager
- NE Nebraska
- EC
Now calculate the savings for an escalator with a 10 Hp motor that runs all the time, it's a couple hundred feet from the panel and the electric bill contains both an energy charge and a demand charge.
And the end result might not be the same for a 208 volt supplied motor vs same motor supplied with 480 volts.That is not really the same thing as having to run larger, more expensive, harder to terminate wires and dealing with box fill issues just because a there is a spot at the end of the hall that needs a receptacle.
To automatically increase conductor size if over 75 feet may sort of work as a general rule, but will still be overkill for some items and not enough for others.
