iceworm
Curmudgeon still using printed IEEE Color Books
- North of the 65 parallel
- EE (Field - as little design as possible)
Charlie's idea of a broken pipe is a good place to start.
Second: Is the booster pump a positive displacement or a centrifigul?
Thirde: When you say, "water on", does that mean the valve at the booster pump suction is OPEN?
Assuming: valve open, centrifigul pump, no flow at nozzles:
The pressure at the pump discharge should be the same as the pressure at the 2"CU feed. No flow = no pressure drop. If this is the case, the valve is not opening, or is plugged.
If the booster is a PD, then interpretation of the symptoms is different
Hummmm - ya' think
ice
Interesting. From what you are telling us, the system is not working now. I would have suspected they have downtime on this system right now.Next week they have some down time for checks.
First: Has this system ever worked before? Or never worked since startup?Pressure gauge at outlet of booster pump reads zero on a 0-60 lb gauge with water on, no pump.
Something is not adding up here.
Hummmm - ya' think
ice
