Indoor Conduit PVC Or EMT Exterior Of Wall
GQROD
New member
Hi i'm new to this forum.
Not sure if this is the correct forum for my question,
Before i apply for a permit
I want to install a 230v 20amp cicuit with cut off switch for an air compressor on the outside concrete block wall of my garage.
Can 12/2 Romex be used and protected with PVC or should EMT be used?
Or is EMT and loose wire ( not sheathed by plastic like Romex ) be used to meet code in Orlando Florida?
Thank you everyone!
I am closing this thread, in accordance with the Forum?s rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. Although your member profile claims that you have a relationship to this industry, your question makes it appear as though you are planning to perform electrical work at your own home, and your profile tells me that you are not an electrician. We are not permitted to provide ?how-to? assistance to a ?do-it-yourself? person.
If I have misinterpreted the situation, if this is a design task that you are performing on behalf of your employer, then send me Private Message to explain the circumstances. I would gladly reopen the thread, and post an apology for the delay and the inconvenience.
