gar
- Ann Arbor, Michigan
- EE
171026-1038 EDT
An induction motor operates by inducing a current in the rotor from the stator. This is a very basic definition of an induction motor.
To be able to induce this current there must be relative motion between the inducing source and the rotor. This is call slip.
Synchronous speed of a motor is defined as f*60*2/N where f is the frequency in Hz and N is the number of stator poles. For 60 Hz and two poles this is 3600 RPM.
To produce any output shaft mechanical power there must be slip. This means that a real world induction motor can never produce any output power at or above synchronous speed.
There is nothing that can be done to the input waveform that can make the motor run at synchronous speed.
Anyone trying to sell you something to do this is ignorant of electrical circuit theory, and is simply a "snake oil" salesperson. Anything else that person says is certainly suspect.
