Grouch
- New York, NY
Hi all,
If you look at the attachment, it's an induction range cutsheet. It's a combo oven with 4 heating 'elements' on the top. If you look at the cutsheet, you'll see the power breakdown for each item in the middle column. How does one calculate the total power for this? Also, why would they show 11,700 watts and 14,000 watts on the top right if both of these wattages exceeds the 40 amp circuit breaker rating that this appliance needs? Dividing those numbers by either 208 volts or 240 volts give you amperages that exceed 40 amps.
