Friend called. Seems someone installed a fan off existing high hats.
It was on a dimmer v
He wanted to replace the dimmer with a speed/dimmer control.
Talking over it I mentioned he was short a wire.
He asked if he where to re hook it back up with the high hats and fan. Which section of the combo speed/ dimmer should he use. I mentioned different types of loads but a guess if he were to use one I would think the fan inductive part. Although that side probably wasn't rated for the watts of the incondescents
Thoughts.
Better a resistive load on an inductive rated switch or inductive load on a resistive rated switch?
Thank you
Thoughts.
Thank you
