drumburg
- Wisconsin, USA
Hello Gang,
I have a question about when an industrial machine requires a rated enclosure. We are looking to use an outside vendor for a piece of equipment that isn't UL listed but might be the only cat in town that can complete our task. Their machine doesn't have a rated enclosure. They are folding steel into a box and placing their components inside as protection. We are having some discussion internally about if this is still NFPA 79 compliant or not and was hoping someone here could help shed some light on the topic. I have searched through the NFPA 79 book for enclosure requirements and can find places that reference the type of enclosures needed if you use but not if a rated enclosure is required at all. I have even found an exception that states:
NFPA 79 - 2015
6.2.3 Direct Contact from Outside an Enclosure. Equipment
enclosures and enclosure openings shall meet the requirements
of ANSI/UL 508, UL 508A, ANSI/UL 50, or NEMA 250.
(See Figure 6.2.3.)
Exception: In the absence of a rated enclosure, the determination of
the suitability of an enclosure as protection from electrical shock shall
be determined by using a test finger as described in Figure 6.2.3. The
test finger shall be applied, with only minimal force, in every opening
in the enclosure after removal of all parts of the enclosure that are
capable of being removed without the use of a tool. The test finger shall
not encounter live parts in any direction.
