My plant is an old multistory wood and brick structure. Many years ago, someone began putting steel plates on the floor to save the wood flooring from damage as equipment and pallets were moved across the floor. A new project is at hand, and now there is a plan to put new floor plates in. My question: Should these steel plates be tied to the plant ground system? What about grounding the existing plates? As I read 250.4 (A)(4), if these plates are likely to become energized, they need to be connected to ground. I can imagine that a portable extension cord could be laying across the floor and could be rolled over by a cart, hand truck, dumpster, etc, possibly damaging the insulation. I can also envision a ground fault in a piece of equipment setting on these plates. Thanks for your opinions on this matter
