urganb
- Upstate N Y
Charging from 110 ac single phase input via full wave bridge rectifier 110 dc out.-- Lets say a 200 volt 72000uf cap.--How would i determine approx. ohms of resistor to use between DC power supply and cap??-- Resistor should go between + and +terminals on rectifier and cap??--How do i determine power(amps)of various DC caps-- I Farred is the same as how many UF??--Could ,say a 600volt cap of same UFs be a better(safer)choice??-- Yes,i use bleed resisters on caps and am VERY careful.Any math needs to be simple,only grade schooled. Thanks,Ben.
