I'm looking to install a inground pool. The main feed from the utility transformer to the home is underground and has been marked by the one call before you dig. The proposed pool site is approximately 8ft from the underground main feed line (polymer pool wall with liner). There will be a concrete perimeter around the pool that will come within 2 feet of this main feed horizontally. Should I be concerned with any stray current from this main feed with the location of the pool. The pool will be bonded per NEC Code. I think there should not be a problem but just want some more opinions before the pool is installed and it's too late. Thank you!
