Adnan Hasan
- baghdad, Iraq
Which type of circuit breaker shall be used for Input circuit breaker of single phase (230 v, 50 Hz, 25 amp) panel board assembly 2poles (1+N) MCCB or 1 pole MCB?
please, which section in NEC cover this topic? thank youEither would be acceptable by the NEC, although a single pole is more common in my experience.
You cannot fuse the neutral, but you can put it on a breaker with its ungrounded conductor in a circuit.
The NEC (National Electric Code, as in USA National) would not apply anyplace where you have 50Hz power and 230V line to neutral.
IEC electrical code requirements differ with regard to whether or not you must or cannot switch the neutral, depending on the type of power distribution system you have with regard to grounding (earthing) of the incoming power from the grid (network). This is a subject best addressed by someone in YOUR country who is familiar with YOUR codes. We are primarily US based with some Canadians because their Code (CEC) is almost identical to ours, then there are a few Brits, Aussies and Kiwis who lurk here because of the (relatively) common language and industry. But even though they may be more familiar with IEC codes in general, the exact answer I think will be specific to your country.
You might try posting in this other forum, there are a lot more Engineers from your part of the world who lurk there.
I don't know of any rule that dictates either. For us it is usually specified by the customer at the bid stage.Which type of circuit breaker shall be used for Input circuit breaker of single phase (230 v, 50 Hz, 25 amp) panel board assembly 2poles (1+N) MCCB or 1 pole MCB?
what is the meaning of handle ties?Single-pole breakers utilizing handle ties shall not be permitted.
actually, in my country, some time we follow BS or IEC and some time NEC depend on the agreement between the contractor and the government.The NEC (National Electric Code, as in USA National) would not apply anyplace where you have 50Hz power and 230V line to neutral.
It's a breaker accessory that bridges the operating handles of two or three single-pole breakers. When installed, they provide simultaneous manual operation of the bridged breakers. They do not guarantee simultaneous trip operation (i.e. common trip).what is the meaning of handle ties?
