Joe5586
- SPRINGFIELD Illinois. USA
Finishing up a service installation in a house in the country which is under the 2005 code, there is no copper water line coming into the house for a second source of ground. The outside currently has one 8-foot ground rod installed with a number two copper ground wire going to a 365 amp panel. There are two 200-amp main panels coming off as a service, my question is do I need to run a extra ground wire from each panel into the meter base to connect to the ground wire going to the ground rod which will have to have another ground rod installed 6 feet away from ita55
