Does it make the same sound as with mustard?
You may want to warn people around before use........
after a couple of uses, no one will mistake it for an actual mustard bottle :wink:
I roll my fiber into little snakes. you can then push the snakes around the wires and into the back of the seal. I use a small dixie cup and mark a line on it in order in insure the proper mixing ratio. I found a basic funnel with a 18 inch hose on the end. The hose on the end make it easy to pour th seal even if it's close to something. As long as you rinse out the funnel before the compound dries it works great.
What tools do you use to pack the fiber? I have tried many things,the back side of a pencil works ok. I know their are tools made for this but our shop hasn't wanted to purchase any.
