cpickett
- Western Maryland
- Electrical Engineer
Lots of debate about staples and switch labeling and nobody comments on the 'temp power' connection!
On to the left, of course.Now, what do you do if you have to install it horizontally?![]()
On to the left, of course.![]()
2008 NEC 404.7 - General purpose switch does not indicate whether they are in the open or closed position.
Interesting. I wonder if there is small imprint of ON and OFF somewhere on the edge of the rocker. This 404.7 is still in the 2017 NEC.
Anyone ever had an inspector fail because of a Decora single pole switch? Maybe they think they are all three way......![]()
404.7 does mention general-use switches, as I bolded to make clear.404.7 Indicating.
General-use and motor-circuit switches, circuit breakers, and molded case switches, where mounted in an enclosure as described in 404.3, shall clearly indicate whether they are in the open (off) or closed (on) position.
We call them 4" raised or Mulberry covers around.here
I know, was just suggesting something that maybe could apply even though it still doesn't quite comply with what code says.404.7 does mention general-use switches, as I bolded to make clear.
Cheers, Wayne
