When a inspector comes to the job either rough or final what do you guys carry with you.
I was told to never carry the code book, Is this a good practice.
I always have a code book on hand. If there is going to be something that's questionable I already have the section I need marked to defend my position. I can't look up things as fast as some people so I like to be prepared.
I don't carry the code book around in my hands , just have it ready in case it's needed.
Likewise, if the inspector needs to, he can borrow mine.If the electrician needs the code book when I go on an inspection they can always borrow mine.![]()
Wouldn't you need the NEC handy to not have to say "I know it's in there somewhere." and be able to cite the article?As an inspector I like when you have a code book around, it shows you care. If we do have something that needs to be discussed then you have something to work with other than, "I've never been called on that before". Also, if you don't agree with me I can show you where that paticular section is so that you know the next time.
Mine is on the laptop, so it's close by.When I point out violations I'll always ask to see their code book. Many times they don't have one with them.
That's what I've always done, and it works.One tip for electricians is go over your job as if you were the inspector.
How difficult is it to remember "90.4"
(and before you jump, no, I don't do that....just couldn't resist)
Inspectors also like to see a worn codebook when you pull it out, it means you have probally been using it. I've had several inspectors make that comment about mine.
That you wore yours out or it doesn't look worn? :smile:
An electrician should go over the job as if he is responsibile for everything on the job, because that's how it is. He really shouldn't worry about the inspector because that's just a formality.
It's nice to get the job signed off but even if the inspector misses a dozen violations the contractor is still responsible so he should correct any violations even if the inspector doesn't notice.
If a contractor is depending on an inspector to catch every little mistake then the contractor is really in trouble.
