When a inspector comes to the job either rough or final what do you guys carry with you.  I have always carry a pen and a pad something to write on,  and maybe a screwdriver and tester.  I was told to never carry the code book, Is this a good practice.
i have the prints, the permit card, a notepad, and a pen.
if it's any amount of work at all, i call for a courtesy inspection, or show up
at the counter during the time when the inspector is available.
i describe the scope of work, and what my plan is, and i ask him what he would
like to see. if he's poopy, he will give a lame answer, like "everything done per the
NEC".
that tells me what i need to know about his attitude.
usually what happens, is we have a brief discussion about means and methods,
and what he likes to see... every inspector has his hot buttons...
with one, he has to have the neutrals on MWBC's identified with the circuits
they serve, preferably with printed labels, not the book version.
another will want to lift the neutral, and apply the "neutral fault test" which
i have whined about here before...
another simply WILL NOT accept a plaster ring unless it's absolutely flush with
the finished wall surface. i know the code specifies an allowable mismatch. it
doesn't matter... not if you want his name on your ticket.
another one want's tube protectors on chain hung lights, even tho they are
10' in the air. no code requirements for that. it doesn't matter.
i get all that stuff ironed out, and go do the work. when i call for inspection,
we're just going over stuff we have already gone over. smile, nod, shake hands,
etc. if i haven't laid the groundwork well enough for that to happen,
then i've screwed up. that's my fault.
best inspection i ever had was a bank of america in northern california i was
doing a remodel on. after the courtesy inspection, and the inspector and i had
spent half an hour walking the job, with a detailed description of what i was
going to do, he just signed off the ticket, and said have a nice day... never did
see him after that... :smile:
something i have noticed recently. i purchased an ideal suretest, and i offer that
if he want's to check outlets... there's no lying with one of those, and he checked
a couple outlets, and asked me if they were all good, and i said yes, and that was that.
professionalism is profitable.
randy
