Mr. Serious
- Oklahoma, USA
- Electrical Contractor
So, I don't think it's allowed to install a wall-mounted light fixture without a box behind it. Obviously, traditionally they were installed that way many decades ago. I previously posted about this issue, asking for a code reference, and someone said the thing to reference would be the manufacturer instructions.
My obvious course of action would be to check the instructions first, then. I have a customer that we re-wired the whole house, and it previously had a little battery-mounted light screwed to the brick next to the back door, but we came back with a surface-mounted round weatherproof box and a conduit coming out of the eaves to feed it. We painted the PVC conduit to match the box to make it look nice, but then the customer bought an outdoor lantern sconce for it, and it doesn't fit right on the box. I was thinking of getting a small sheet of steel or aluminum to put between the box and the fixture, to at least make it sit level, even if it still sticks out away from the wall because of the box. But, the customer thought about it for a couple of weeks while I was busy with other things, and then said he would strongly prefer the fixture be directly onto the brick.
Would you guys normally just screw the fixture directly to the brick and forget about having a box behind it? Or is there some trick you use, to get a box into existing 100-year-old bricks?
