JOHNEO99
- Northern Illinois
Hello
So I am going to move a 600 amp ct cabinet with meter attached from the side of a house 250' to the back of the 8- car garage. I've spoken to the inspector and he said I didnt need a main disconect in the ct cabinet and that the existing main disconnect inside the house would suffice as the main diconnecting means even though the meter cabinet is behind the garage out of sight and way far from the house. Im sure that there should be a diconnect in the ct cabinet and I told him this but he said not to worry about it so I wont becuase im just gonna use the existing cabinet now which is far less expensive.
There will be a directional bore with 2-3" poly pipes going from existing ct location to the new spot behind the garage. I am pulling 3-350 mcm thhn thru the poly and sleeving down from ct cabinet and at the point where the main exits the via LB's and two IMC sleeves to underground.
Do I need to run any other wire with the 3-350's like eg or gec or will the neutral suffice here?
If there are any other flaws in this proposed installation feel free to let me know.
