ttlazar
New member
- Pasadena, CA
Can you install a panelboard switch above 6'7" if it is going to feed equipment and it is not going to be used as the primary means of turning the equipment off and on? Reference NEC 2005 404.8(A). I will have the main breaker of the panel at about 4' Above Finish Floor, but the top four breakers will be above 6'7". My inspector believes I cannot install the panel b/c of 404.8(A). I would also like to give him an example of when "a circuit breaker is used as a switch" and when it is not.
