Here are 3/4 rings with 5/8 rock.
Looks good....... it just takes a leap of faith to try it for the 1st time. Most never will for fear of the ring sticking out too far.
JAP>
That is part of it not all of it, the other part of it is the thickness of the flat part of the ring.
Grab a ring and mesure it, you will see what I am taking about.
JAP>
I guess it is.
When we had to start grounding switches, we would leave the hot in , ground long enough to wrap from one switch to the next. Didnt fly.
In a 4g its 10 grounds and a blue wirenut.
Sent from my SPH-D710BST using Tapatalk
I guess it is..........
I havent tried it but had heard of it..
I went to a little biddy 6 plug wall rough. It was outside of my usual drive in miles but I thought if I put the devices in now, im already standing here and it passes inspection then my next trip it ll save me some time.
That little biddy 6 plug rough maybe doesn't get drywalled by same crews that do larger projects, but rather a smaller one or two man crew that does a little bit of everything. Often those guys are not so reckless, they are also the same guys that have to tape it and will be a little more careful hanging just so they don't have as many repairs to make.The drywallers will smash them into the boxes, then install the drywall and use their router to cut the opening...I would not expect that there would be a usable device left after they finish.
Yes, so you are better off running metal raceways and pull conductors after they hang the rock:happyyes:Isn't the standard to push in the roto zip until it hits the back of the box and then come forward again?
I hardly ever connect anything at rough in. When using NM cables the sheath is not even stripped most of the time in the boxes at rough in.On a rough in inspection in resi its not so easy to see if the grounds are made up and in cases with multiple devices , that there is a ground for each device. In commercial green screws sticking through the box usually satisfies the inspector.
It does seem time consuming to strip in a house only to go back and crawl across the floor again cause the plugs are horizontal 1 block off the bottom plate. Ugh.
Agree, respect them and they usually will respect you in return, but don't let them walk all over you either.AHJ is for Authority Having Jurisdiction. Sounds like you've capitulated to what has become your AHD..... Authority Having Dictatorship. Once you let them roll over you, you've given them the ability to continue to do so again and again.
Single cable entry into a nonmetallic box - nothing to make up until you install the deviceHere the grounds have to be made up for a wall rough inspection
Sent from my SM-G360P using Tapatalk
One electrician I knew said he breaks the ears off the devices and installs then before the rock, this way he can adjust them out if need be. Don't know if that's a code violation or not, would probably be ok for switches but a problem with an outlet not flush to the wall.
