KentAT
- Northeastern PA
Is it permissible to add surge protectors to an intrinisically safe circuit without them appearing on the intrinsically safe device's approved control drawing?
More specifically, we have an intrinsically safe flow measurement system operating in a Class 1, Div 1 building (outside is Div 2). The customer who is receiving the natural gas from our pipeline (local gas company) will be adding a circuit to our system so they can also receive the identical measurement values. They are concerned about surge protection and want their circuit to be as follows:
PLC (uncl). > barrier (uncl) > surge prot (uncl, but rated Div 2) > field wiring underground > above ground JB w/ surge prot (Div 2) > into Div 1 > into intrinsically safe enclosure/system.
The seals, etc are not an issue as all will be done properly. I just never added or changed anything on an I.S. control drawing before.
The surge protector is an MTL Instruments model SD16, which MTL shows in their product brochure as being approved for such installation.
Kent
Kent
