Nizar
New User
- Indianapolis, IN
- Physician
Hello
I just installed an intellicenter panel to help run my hot tub. I have it wired correctly I think. I am running an Intelliflo vsf pump with it. As of now I have the pump running via bluetooth and it works well. I have to blower connected to AUX 1 circuit, and it also works. I am trying to control the pump and blower via the panel and the Pentair app, and running into an issue. I connected the pump to the panel using the 22 awg as recommended in the manual to the com port. Once I did that I could not use the bluetooth option,but I was not able to operate it either via the physical connection. The pump and blower are connected to the 1st high voltage auxiliary relay.
I tried separating the pump and blower by leaving the pump on the 1st AUX relay and placing the blower on the second AUX relay. I then connected the pump to FLTR low voltage circuit and the blower to AUX 1 circuit and nothing worked. I have a solid magenta LED on the 'Connect' pump. What am I doing wrong?
