Intellicenter programing
Nizar
New User
Indianapolis, IN
Physician
Hello
I just installed an intellicenter panel to help run my hot tub. I have it wired correctly I think. I am running an Intelliflo vsf pump with it. As of now I have the pump running via bluetooth and it works well. I have to blower connected to AUX 1 circuit, and it also works. I am trying to control the pump and blower via the panel and the Pentair app, and running into an issue. I connected the pump to the panel using the 22 awg as recommended in the manual to the com port. Once I did that I could not use the bluetooth option,but I was not able to operate it either via the physical connection. The pump and blower are connected to the 1st high voltage auxiliary relay.
I tried separating the pump and blower by leaving the pump on the 1st AUX relay and placing the blower on the second AUX relay. I then connected the pump to FLTR low voltage circuit and the blower to AUX 1 circuit and nothing worked. I have a solid magenta LED on the 'Connect' pump. What am I doing wrong?
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Electrical Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Reminder to all members, if you see a questionable post, feel free to report it by clicking "Report" at the bottom left corner of the post.
