mcclary's electrical
- VA
If you had an inch and a half,,,,you could have flush mounted it,,,,why was it sticking out?
Furring strips takes me back to the fifties, and do it yourself jobs.
Just an aside note: I have found that a 5/8" ring works better for 1/2" drywall, 3/4" for 5/8" drywall, etc.Mount either 1-1/2" deep 4 sq metal box with 1/2" rings or use carlon non mettalic 1-1/2" x 4" boxes with 1/2" non metal rings. You will be flush after sheetrock is installed.
Your comment caused me to see the ambiguity in the description in the OP:Gluing sheetrock does not exempt you from putting receptacles on that wall,,,,,It's still a wall line.
I read "new project" and understood work in an existing dwelling. That is how I framed my comment.I'm working on a new project where the GC wants to fur out the exterior walls . . .
Interestingly, the 50% rule is applied globally to the entire premises by floor area here.In my experience, in the jurisdictions I've worked it, the existing construction has to be open to framing for 50%, or more, of the wall area of any given room before the local ordinance claims that the current version of the NEC is invoked for that single room.
50% of the "floor area"? How is it phrased? I'm not getting it.Interestingly, the 50% rule is applied globally to the entire premises by floor area here.
If you have a 2500 sq.ft. building, and you renovate 1250 sq.ft. or more, the entire premises must be brought current for all trades: us, plumbing, HVAC, floor-spans, insulation, etc.50% of the "floor area"? How is it phrased? I'm not getting it.
:smile:I can find the legalese if you really want to see it spelled out.
I agree, a method that should have expired years ago when Chanel and Rickels went out of business.
What kind of box would you use with only 1.5" distance between the finished surface and the wall?
