I recently looked at a printing press which is rated 230volts, 3 phase. The voltage at this fascility is 3 phase, 4 wire 240volts with a grounded center leg. The actual measured voltage is around 246 to 248 volts. I was wondering if this warrants the need for a buck transformer or will the equipment be okay without it. This press is fairly basic, no electronics, just two motors and a 120v xfmr for the controls. Thank you.
