al hildenbrand
- Minnesota
- Electrical Contractor, Electrical Consultant, Electrical Engineer
This is one of those things that has quietly snuck in under our noses over the last two decades.So who eventually figured out that they were using the EGC as the Neutral conductor when their device was attached to the wiring system?
The pressure to do it comes from Design and from Marketing as Corporate strives to keep or gain market share. All manner of switches can be made "marketable" by adding design features that include LEDs and little microprocessors that have to stay energized and working even when the switch is on. Putting a battery in was a possibility, but very few manufacturers chose to do that. The only way to get a good supply for the solid state features of the switch was to add a neutral (which many switch boxes in the real world don't have) or use the EGC.
Creative engineers, et. al., took advantage of the very low current needs of well designed solid state circuitry to exploit the listing standards allowance of a tiny amount of current "leakage" into the EGC.
Meanwhile, in the field, as we install there "smart" devices, just think of all the switches with a hot, a switched leg, and an EGC and no neutral that you've installed. Anything that keeps the circuitry alive while the hot is solidly connected to the switched hot (the switch is ON) has to be using the EGC as the "return" conductor for that circuitry.
