richwaskowitz
- Shelby Twp. MI, near Detroit
I know that cables have to be secured to a framing member (stud / joist) at the required disances before they enter an outlet box. My question is, what if the cable is entering the space above the box through a drilled hole in teh stud which is only a few inches away from the box (let's say that the box does not have integral clamps) and there is no room to even get a staple in there? I have run into this when for example an outlet is located near the floor and under a tall window where the space between the bottom plate and roughed-in sill is only 6 inches. There is barely space to get a hole in there. Is a staple required when the cable is so close to the box. If the box has clamps, does this change anything?
