Can Emt be considered to be supported by passing through a CMU wall? The holes and web area in the cmu are filled with concrete or mortar around the EMT where it passes through. The EMT then enters boxes or surface mounted lighting fixtures on each side of the wall within 3' of where it exits the wall.
The actual case is where the conduit enters a fluorscent surface mounted strip fixture on each side of the wall, within 18" of the wall. The EMT enters into a knockout in each fixture. The wall the fixtures are mounted on is perpendicular to the wall the conduit passes through. This allows the EMT to pass straight through the wall and into the fixture.
