Is it acceptable to use wire nuts in the service panel?
jot30
Electrician/Electrical Inspector
When installing an auto-transfer generator, per nec, is it acceptable to use wire nuts in the service panel, to make circuit connections to the new generator transfer panel?
Yes, not a problem at all.
Yes-- read art. 312.8 but don't stop at the first sentence. ;)
Yes.
It is easier to pass a camel through the eye of a needle than it is to violate the code section (312.8) that addresses splices in gutter space in your average residential load center.
peter d said:
Yes.
Which one did you do? :grin:
peter d said:
Yes.
Getting biblical on us, Peter? :grin:
Thanks for the help...Inspector had different take!
God Bless.
Regarding...Thanks for the help...Inspector had different take!
I meant it!..... The God Bless too! The inspector told us we were using the service panel as a JB. "a clear violation" So thanks for the code help.
Yep, the violation was a clear as mud.:D
Glad you got this cleared up with the inspector.
Chris
