SparkyDrew1999
- Arizona
- Young electrician
Old existing panel has to be changed for an updated panel according to the single line but the existing 350mcm thw wire has no indication to be changed. Also the calculated loads on the panel phases are A(226.9amps) B(216.4amps) and C (240.1amps). So, basically the loads are going to be less than 250amps so the 350mcm thw wire should be fine? but then the main breaker is 400amps, so therefore the wire is not under code. but again the engineer did not mention anything about changing the wire. Am I missing a special code or something??? Please help me.
-Drew.
-Drew.
