jumper
- 3 Hr 2 Min from Winged Horses
..... not all rules consider the potential outcome....
True.
It says what it says. We often disagree on what it means, though....because many of us disagree on what it says.
I'm 22 years old and thinking about going to trade school. The issue is that I have a misdemeanor charge that I didn't get convicted for and I got it expunged. Is it possible for me to still be an electrician?
Hallowe'en prank, maybe?No problem. Look at my screen name. I was charged with three felonies and 4 misdemeanors for a hollowed prank ...
Absolutely
But even if you weren't expunged I think that in most cases its going to depend on what the charge was for in order for job prospects to be impacted negatively. Generally speaking for most areas it tends to go this way.....
Felony theft ( esp. repeated)- likely a non starter- prospective employers look at it like if you did it to someone else, then you can do it to them.
One time Misdemeanor theft- nobodys gonna care about the time you got nailed when you boosted from Walmart in 2005....
Aggravated assault (Felony)- no biggie-(unless the the dude you worked over was a former employer who fired you.)
Simple assault (Misdemeanor)- nobodys gonna care that you slugged some moron and spent a few hours in jail.
DWI/DUI-One or 2 old ones (more than a couple of years have passed) is ok, anything more/more recent, than that can be problematic.
Up to a couple misdemeanors or low level felonies for a little dope that happened years back- just like the other stuff above, it boils down to this-As long as you can show that you are/have been keeping your act together- you come off as mature, you pass the pee test, it happened a more than a while ago, you'll be fine with most. Besides whatever the case was, you were expunged- thats good enough for a lot of prospective employers-you shouldn't even mention it.
..i can think of a number of people who can't even agree how far
winged horses is. or which direction. :?
Boo, hiss, boooooo, boooooooo.......It appears the consensus is that you should not have any real trouble getting a job in the electrician field unless you insist on installing receptacles with the ground pin down.
actually, a prison record doesn't hurt all that much for a security clearance, they are more interested in forthrightness and the nature of the offence. character[/QUOTE]The only time a prison record really hurts a person if if they need a security clearance to work on a job.
