iwire said:We will have to disagree there, I can't see that it really matters.
The FD would not hesitate to hit the building main if they really felt the need to turn off that unit.
True, if the building had a main..I've seen a few that don't..
The building I'm in now doesn't have one, we have five units and only the panel I did for my unit has a main in it..it's downstairs in the doghouse.
Since there are five panels, and each has more than a single pole breaker in it, does this make a violation of the "six throws of the hand" rule? Maybe I should get a pic of our service here and start a new thread...
Come to think of it, in the case I cited above, a main in the panel in the unit would have been useless..the fire started in the room with the panel, and made the panel inaccessible anyways.
So I stand by the "good idea" theory, but is it cost efficient or a major enhancement of safety? Most likely not on both counts.
Edited to add:
brianjohn said:60 amp main in the apt panel, then a 60 amp CB in the MDP located in a locked electric room. Problem occurs that trips the 60 amp main. Which one trips? The redundant 60 amp in the apt is serving no purpose.
Good point. Wanna bet which one will go first most of the time?
The only real saving grace of the one in the unit is it is a quick cutoff for all circuits in that panel, and if maintenance needs to be done in the panel you have a disconnecting means in plain sight while you're working.
