I was recently asked to troubleshoot a tripping basement breaker. The cause was damaged insulation in a pull chain luminaire box. Not quite sure what happened, if the feed thru neutral was loose and overheat and melted the insulation on the hot, or the wires were not dressed properly and this was a latent failure.
Client reported house was built 30 years ago, and no work was recently performed.
To be thorough, I decided to inspect the home run and found significant corrosion in the panel.
Based on what I see, I think it wise to recommend a panel replacement, but curious on others opinions.
Interestingly, I see things in the photos, that are more obvious now than then when I was there.
