petersonra
- Northern illinois
- Semi-retired engineer
Just so you know it is likely just a fuse block and fuses that you will need to mount in your own enclosure - there won't be space within the drive for them.
I have seen some VFDs that have a spot inside the drive itself where fuse blocks can be mounted. They were a real low end drive though, Japanese I think, not something I would ever select. There were actually a couple of tapped holes for the odd ball fuse blocks supplied. The fuses were something odd as well. I don't think the fuses were anything one would typically use in the US.
