Is there a different formula for voltage drop...
sbyrne
when dealing with DC compared to AC?
I was flipping through a customers specifications and came across something on voltage drop. It said:
...because this is a DC circuit, you must use the "there and back length" (one way length x2) when calculating voltage drop.
I have never heard of this. Well, NEC shows formulas using reactance, etc. which is different from the typical
Vd = 2k*L*I/Area
I don't undestand where the customer is coming from. Which leads to another question I've always wondered:
Is the 2 in the equation above there to turn the one way length into a "there and back" length? or is it there for some other reason? If so, what is that reason?
You almost always go there and back via the wire. I've heard of (not seen) RARE, earth return systems. I'm guessing the worms don't like those?
