Is there a WP Romex connector?
77401 said:
And, Bussman must not do any residential.
Actually I do mostly residential. I won't say that I have never run Romex to a WP box, but if I have my choice, I use UF cable.
Mark
Mark
Why would you use UF if installed in a WP box that is getting a connector that will be within the confines of the wall or soffit as the case might be.Take a flood light mounted on a nail on box under an eave.Why is it any different from a retro fit where a WP box is used.The cable assy. is in a dry location ,connected by a nail on within the eave or within a connector within the soffit itself.The trouble of stripping out the UF as compared to NM isn`t worth the effort.Would you run UF for an a/c unit disconnect outside ??? I mount my disc. on rough in ,so the building covering be it stucco or what ever will eliminate any water infiltration.Thats just overkill and money not well spent.
